rogueflyfisher
- Aug 6, 2005
- 5
I've got a Merc 500 50hp outboard 1968. Runs fine starting out, at high speed, with a full tank.... then after several hours of trolling at low speeds... when you try to go full throttle, it kind of sputters and won't run as well as it should. New gas tank. Same problem.<br /><br />After running at full throttle (sputtering, and barely getting on plane)... the primer bulb will sometimes get soft. But, after pumping the bulb, the motor doesn't respond. It stays running at a "moderate" speed... not like it should at full throttle.<br /><br />This is about 1/2, or 1/4 tank of gas, now after trolling for awhile.<br /><br />After filling the gas tank again, and running at full throttle, the motor slowly starts getting back to a good speed.<br /><br />Could this be a bad fuel pump (diaphragm)?<br /><br />It starts and runs excellent in idle, slow speeds, and high speeds early on. Just after trolling around for a few hours, when you want to go fast, it hardly has the power to get the boat on plane.<br /><br />Why would it matter how much gas is in the tank?<br /><br />It seems to do better with a full tank, at the beginning of the day.<br /><br /><br />15 foot fiberglass runabout... 50 hp Merc. 500 - 1968.<br /><br />Any suggestions?
