Edgar F Hodges
- May 12, 2002
- 2
While cruising at about 25 Mph, my engine suddenly lost power and went into what I would term "hi-rev", as if i had engaged the clutch on an automobile with the gas pedal down. Leaving the engine running I put it in gear and was able to limp home, unable to go any faster than about 5-10 Mph. After about an hour and a half, the power finally gave out. The engine idle sounds just fine, not running rough at all, idleing beautifully, just no forward motion. I was able to turn the prop by hand out of the water, engine in gear - I did hear a clicking sound, what I assume to be normal when not powered with the prop moving. I have heard of "shearing the cotter pin" but the prop assembly seemed firmly attached. Any thoughts? How much to fix? I love this engine and dont want to have to replace it. Much thanks - Edgar
