snowfleurys
Thread starter- Joined
- Jun 22, 2003
- 2
I have this old 55hp that start and idles fine till about 2000 rpm. It starts to miss and then will not rev any higher. Now and then it will act proper and rev up and plane out nicely. Out of water it will hit readline every time the throttle is punched. Has the carbs redone and fuelpump replaced, new rotor, coil harness and majority of wires replaced due to cracks. I hear these old 3 cylinders are famous for the battery cd ignition to give out, but not work partially. A new ignition pack is worth double the motor, so i'm not quite ready to try that yet. Any suggestions?
