68 evenrude 65 hp starter
Franko
Rotation Of fly wheel clock wise <br />should bendex be counter clock wise how to change
corm
Re: 68 evenrude 65 hp starter
Hi,<br />Are your battery cables hooked up right?<br /><br />...have fun...corm
steelespike
Years ago I had a starter rebuilt.They put the end plate(where brushes are) on 180 degrees out<br /> of position.I changed it back and it worked fine.<br /> Maybe that is your problem.
JB
Hi, Franko.<br /><br />Starter motors are series wound. The only way to reverse them is to reverse the relationship between field and armature.<br /><br />What Steelspike describes is exactly that.<br /><br />Take the end plate (with the brushes, etc. attached)off and reverse it. That should get your starter working right again.<br /><br />Good luck. :)
