My Johnson outboard currently uses the following gears:
390970 - Forward Gear
307485 - Reverse Gear
308617 - Pinion Gear
I have been looking at the 377877 gear set which includes forward, reverse, and pinion gears. Based on the pictures that I have seen, it appears that the gears in this set are identical to the gears that I have. I was curious if anyone could tell me if this gear set would work as a replacement?
I just got a quote of $627.50 for the forward gear and $268.36 for the pinion gear so I?m trying to see if there are any other options.
Thanks in advance for the help!
