The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Is it alright to use a muff on this motor and if so which hole am I covering? (I know it's the stupid question of the day) Just don't want to damage the motor. My guess is its the larger hole in the upper part of the lower unit on the left side.
Hi Fajsam<br />The 1967 60 was fitted with two differnt l/u's. Both pick up water from the front of the skeg, behind the propeller. You would have to have a speical device for flushing or a tank (garbage can). Reg muffs won't work. This assumes you do in fact have a 1967 60 hp.
Thanks ALCAN for the info. Is the special device you mentioned available in a local boating store?<br /><br />I guess I can check the next time I go. Thanks
