filled up a garbage can with fresh water, dropped the sea horse in and ran it for several minutes. The water had a brown oily slim which had a strong fuel smell (I have a headache from the smell). When I removed the motor from the water, the lower unit was covered with this oily brown slim. What is up with this? Cause? Solution? or no worries cause of the age of motor? Please advise. Thanks. After lowering the motor this brown slim was oozing out the pee hole on the left side of lower unit and the pee hole next to the lower unit exhaust.
