Fisherman '78
- Jul 11, 2007
- 9
I have a '67 Johnson 100 hp outboard that isn't getting fuel into one cylinder. As a result the engine runs on three cylinders. The three cylinders that are running are functioning properly. I have checked the wires and plugs repeatedly and they are in good working condition. I ran a compression check and that was alright as well. I adjusted the carb with no results, then I sprayed cleaner into the adjustment hole on the carb. The results were the same, no fuel in that one cylinder. Any ideas?
