67 Evinrude Johnson 33hp stuck in reverse
cangolden
Hi can't get gear out of reserve..did order a manual ..but would like to know how to get the gear working again? Thanks
Joe Reeves
Re: 67 Evinrude Johnson 33hp stuck in reverse
I assume that it was working/shifting fine at one time, then something happened, and suddenly it was stuck in gear? We need a little history on that problem.
cangolden
Hi Joe... the gear was stuck in forward when I got the motor..now in reverse.. someone said I have to take the powerhead off to get to the gear lever.. hope this helps...
Joe Reeves
No, that really doesn't tell us much. The gear shift lever shaft might be frozen just under the powerhead, the shift linkage may have come apart inside the inspection plate (halfway down the exhaust hsg) which would result in a very movable but useless gearshift handle, the lower unit may have had water in it which has caused rusting, etc.<br /><br />Disconnect one bolt from the shift connector inside that inspection plate, then drop the lower unit to see if the problem is in the unit or elsewhere.
cangolden
thanks ...I'll let you know the status in a few days or so :)
