G'day my evinrude won't start without ether spray into the sprak plug holes. i have checked ignition sealed the crank cases checked float level aven switched floats but it wont start unless you use ether spray. but once it starts it will run fine and when you stop it and start it again the fly wheel spins 1 quarter turn and its started. i cant think of anything else causing this starting problem un less float level is wrong. once the engine has been left for 40 mins it wont start again. any ideas?
