Okay, so I thought that I had fixed the problem with my motor.
I went out fishing yesterday. That was an outing I'll tell ya.
Anyway, the lake was getting a bit choppy, and I had been trolling all day, and my engine just decides to die.
Now, while trolling, the engine would idle smoothly, but about every minute or so it would misfire. Pop whatever you want to call it.
That wasn't an issue, it idled for hours like this.
But once I had trolled across the lake at the end of the day, the motor died.
It would start to die, and seemed like when I squeezed the primer bulb, it would run a bit better for a second, but would still die.
I wonder if it might not be the fuel pump.
It would run just great at WOT and mostly anything above idle, but just wouldn't idle.
The low idle screw didn't change anything.
So, I'm still chasing this problem down it seems.
And just for history, I have done these repairs.
-Changed plugs.
-New condensers, and breaker points.
-Carb rebuild.
-Compression is even on both cylinders at 60 when using the pull rope.
-New filter screen and gasket.
-Changed plugs.
-Carb rebuild.
