Re: "66" Evinrude 40hp problem
Should you have proper spark on both cylinders but lose one cylinder's spark as the throttle is advanced, the problem could be as follows.<br /><br />(Magneto Armature Plate)<br />(J. Reeves)<br /> <br />If the armature plate has a a loose fitting, wobbling motion (the plate that the points, coils etc are attached to), it is usually caused by a slightly worn support ring. This allows the point setting to change erratically as the armature plate turns.<br /> <br />The cure is to remove the armature plate so that the support which is attached to the powerhead with 4 screws is visible. Then, with a screwdriver and hammer, or some tool of your choosing, and looking straight down at the support ring, make an indentation at what would be called the 12, 3, 6, and 9 O'clock positions. Install the armature plate and check for a smooth turning wobble free movement.<br /><br />You may need to do that procedure a few times to obtain the proper fit (not too tight, not too loose), but it's worth the effort. <br /><br />On the other hand, if the spark is perfect all the way through the throttle range..... if fuel is blown back thru the carburetor throat when the engine is running, the usual cause is a faulty/broken intake leaf valve.<br /><br />Also, on some models (if a fuel problem), one cylinder will run lean if the carburetor is fouled or adjusted improperly even though only one carburetor is involved (it happens).
