Hi again,
I removed the flywheel, set the points, finished decarb... hits on both cylinders at higher rpm... suppose a tune up kit plus spark plug wires might help.
Is there any way to test the coils with a multi meter?
Where is the water outlet for the cooling system? It spits through the exhaust, but there is some kind of opening above the prop... water draining out of that opening... is that the cooling outlet?
The throttle arm on this little engine doesn't want to stay put now, whereas before I removed the flywheel and one of the coils it would stay pretty much where you set it when running. Now when running it wants to go to shut off... what have I done?
Can't find parts on the web... need to call my dealer I suppose.
Thanks again for your help.
stevek
stevek
