Will not start up. Had in water and it started after a few trys, and stopped , would not start back up. Brought back up on land and still wouldn't start. It cranks ,but won't start.
Spray wd40 in carbs and try. if it fires you<br /> have a fuel supply or choke problem.<br /> If the motor hasnt run in sometime you should<br /> check the fuel system from tank to carbs. <br /> If motor doesnt fire check for spark.Chack the kill switch or ignition switch should be open to run, closed to stop.<br /> Good luck.
