youronlysin
Thread starter- Joined
- Apr 24, 2016
- 4
Been having issues with my 65 hp Johnson. 1973 model. I've eliminated compression and spark issues, rebuilt the carbs and fuel pump but found leaks in the fuel lines and have replaced that mess. Now, I can finally get the boat on plane and up to rpm at wot. Below a certain rpm, the middle carb won't fire unless I cover the carb and choke it a bit, then it runs fine. Once I give it a bit more throttle, it will run on its own and works great. When I rebuilt the carbs, I had one carb where the low speed jet was stuck and I couldn't remove it. I did clean it out in place with cleaner and compressed air but it's got a slot in it to get a screw driver on it and I could tell the brass was broken around the slot. Are these jets so finicky that this could cause my low speed idle from functioning properly? Anyone have any ideas on how to get that frozen jet out to replace it?
