Re: 1965 65 HP Mercury Starting Problems
I have 65 hp that runs well after I spray startin fluid into the carburators. When the engine is turned off for about 10 minutes I have to use starting fluied to resart. If I try and start within the 10 min, estimated, the engine fires right up. The carbs were rebuilt this spring. It did start at one time this summer but it didn't have high speed. Now I have high speed but it won't start. The engine will start with gas sprayed into the carbs. the shop that worked on the engine said there is a ring on the piston that draws fuel into the carbs. Is there anything besides replacing the rings that I could try?
