Sheltering
- Oct 31, 2012
- 25
I have a 1993 Johnson 65 hp outboard. I purchased boat (16 ft Bayliner) & motor last fall and never really had a chance to test it until now. Outboard would not idle nor run properly.
I removed and cleaned all three carbs, but still had the same problem. I took boat and outboard to a boat shop, thinking that I needed a more experienced person to adjust the carbs. After $325.00, I was told by the shop that the motor was surging and that I probably needed to replace the stator. I took the boat as it was and put it in the water only to discover that it was working exactly the same as before the shop. After one hour of attempting to get the motor to start and idle, I switched fuel tanks to one that had high test gasoline, and discovered that, after a while, it started to idle and run pretty good. I now finally had the courage to venture beyond the dock and after about one hour it was still running ok.
Is it possible that I have a bad stator and that the higher octane gasoline is compensating for a weaker ignition, or is it that this outboard will only run on the higher octane gasoline?
Any advise would be greatly appreciated.
Don in New Brunswick, Canada
