65 hp Evinrude surges
simonmeridew
My friend has a 15 foot whaler with an older, maybe 80's model 65 hp twin evinrude. <br /> It starts fine from cold, runs fine at cruising speed for maybe 1/2 mile, then starts<br /> loosing rpm's, and starts surging, maybe at a rate of one surge per second. At this<br /> point it doesn't seem even to idle well. We tried changing plugs, same thing happened.<br /> Can we spray something into the carbs when it starts surging to see if problem is fuel<br /> related? Probably won't happen when in the driveway on the muffs, tho not sure.<br /> simonmeridew
Bear
Re: 65 hp Evinrude surges
Try squeeze the primer bulb. If it picks up it's time for a fuel pump kit.
simonmeridew
we tried squeezing the primer bulb. It's hard as a rock. BTW, it's an '84 motor.<br />simonmeridew
