I've got a 40 h.p. Johnson that is in pieces. The electronics from the key switch to the starter stopped working and I had to short the starter to get it to turn.
Then when checking the lower unit, I found milky white lube indicating a leak into the lower unit. Is it possible to get parts for this motor or is it a lost cause??
