1973Chieftain
- May 31, 2010
- 1,298
I just purchased a 15' aluminum Starcraft Jet (about 450 lb) powered by a 1965 33 hp Evinrude. So far, I have only been able to get up to 16 mph with it wide open, with 2 adults in it. On the face of it, does this seem right? I had thought that with as light of a boat as mine, and from reading on these forums of others with similar boats, that a 33hp should be large enough to push it faster. There is no tach on the boat so I am unsure of my RPMs, and I did not notice any sort of roughness in the engine which seemed to be running smoothly. The hull is rated for 50 hp, so I know I'm a bit on the low end for power, and I am trying to determine if there is a problem with my engine, or if I should repower with something larger. I understand that there are many factors related to the speed of a boat, it just struck me as slow. Any thoughts or guesses?
Thanks for the advice!
