Re: 63 rude 40hp no spark. where to start?
Paul,<br /><br />The coil was obviously cracked from age. I will pull the flywheel again tomorrow, and check the wires. Ignition is right on if I am not mistaken. I spent a lot of time rewiring the whole harness so I am pretty sure that the MAG wires you are thinking about are wired correctly. (Will check though just in case). thanks <br />Shear pin was good...<br /><br />Good to hear that you think that the kick back is not mechanical. I will check the fluid levels just to make sure tomorrow. I noticed that the high tension wires, were not aligined like they previously were.. If the new (bottom coil wire was not properly inserted into the coil) do you think that this might be the problem? I pushed it in pretty well but it didnt look like it went in all the way? Maybe time for different wires?<br /><br />I'll figure some stuff out tomorrow and let you all know.<br /><br />I appreciate your help,<br />Sal
