63' merc 850 lower unit compatibility
LV2BT
Hoping someone can help, I have a 1963 inline 6 merc with bottom end issues. It appears the previous owner tried to remove the bearing carrier and broke it in half. The 85hp power head still runs as far as I can tell. Since I can't find a 63' lower unit, I am considering newer parts but can't find any compatibility info earlier than 1965. I have 2 basic questions:
1 - Can the 63' lower unit be swapped with a newer one, say late 60's early 70's?
2 - Would the bearing carrier from any newer unit fit my 1963?
Any help would be appreciated.
As a side bar, it would be nice if someone could publish a merc lower unit/upper unit compatibility chart as it seems to be a popular questions.
crem1
Re: 63' merc 850 lower unit compatibility
Any chance of getting the info on a 73 MERC 500 lower unit? Is it a pin or a stainless drve shaft and how interchangeable is it with other years?
Thanks
OldMercsRule
Thanks
There is a chance if ya start yer own thread. Better 'splain what ya mean by "pin". JR
OldMercsRule
I dunno specifically 'bout the '63 850 inline6.
Chances are if it's Black it will fit.
The first Black Lady was the 1962 Merc 1000.
Hopefully: some of the big guns here will say fer sure.
Me "guess" is yes, butt: I don't bet big $ on a "guess". JR
LV2BT
Thanks JR,
I appreciate your guess. I thought I read somewhere that I might need to modify the shift linkage however. I'm not opposed to this idea but I would like to confirm what I am getting into before I go out and buy a different year. This fixer upper is only intended to get me through 1 or 2 seasons so I don't really want to sink big $$ into it. I'm hoping in a few seasons, I can scape up enough cash to get a remanuf. 90' 115hp w/tilt & trim.
LV2BT
oh... and yes... it is black but it seems there is some white paint showing through here and there behind trim pieces etc...
emckelvy
Here's some info which may help:
For any later-style lower unit being adapted to an older non-exhaust-tube motor, you'd have to shorten the shift shaft; plug up the side vents; and modify the brass reverse lockout cams & the plastic spacer spool from your motor to fit the later-style unit.
Some later-style units have different ways to seal the driveshaft/crankshaft area; early "new-style" units have an O-ring groove same as your 850. Later units use a crankshaft seal assy with non-grooved driveshaft. For these, you'd either need to cut your own O-ring groove or pull the powerhead to press in a seal assy at the bottom of the crank. I've done the O-ring groove with a grinder wheel and that method works fine. If you should ever have your powerhead off for R&R, the crankshaft end seal is a nice upgrade.
At any rate, you could use a much newer unit with benefits such as stainless driveshaft & improved gearcase design, and different gear ratio. The 2.3:1 ratio (found in 66 c.i. Fours; "800", "850", 80hp, 75hp) works very well with these older inlines and improves your range of prop size selection. Typing this it comes to mind that later model 650-4's had 2.3:1 gears as well.
Note that you can find plenty of 2:1 gearboxes in later-style as the majority of Inlines used that gear ratio. Don't use one from an early 1150 or 1350 as the 1.78:1 ratio wouldn't be a good choice for your motor.
BTW if you were to find a "650" lower unit of the same vintage as your 850, it's a bolt-on with no mods required.
Anyway, that's in in a nutshell!
Once you find a newer lower unit we can go into the modifications in more detail. I did this to my old '64 850 (converted into a 1000) and it worked great.
HTH.............ed
LV2BT
Ed, your post helps a great deal. Based on this, I'm no longer concerned about getting a newer unit. I will certainly be looking for the 2.3:1 gears. I don't expect a problem finding the newer units as I am near a decent size boating comunity.
Once I find a unit, I will certainly be posting back for details and will likely post the conversion process for others to benefit.
Thanks again,
CT.
