jackiebpratt
- Sep 4, 2004
- 6
Hello all. I have a 'new' 63 Johnson 3HP. Seems to run relatively smoothly, and starts easy enough. Feels like there is decent compression. Water is spitting out the coolant exhaust. Using 30W Non-Det at 24:1 as per some other posts here.
1st Question: After running for several minutes (maybe about 5-10) motor dies. Will start back up, but then will only run choked or half choked. It had been sitting for a while before I got it. My guess is dirt in the gas, and that it clogs the filter or bowl/carb after running a little. I look to tear it down this week sometime and clean out the fuel lines/system.
Second Question: Although the exhaust is spitting out some water, it isn't a steady squirt, but is much more 'airy' then watery. I am thinking that maybe the impeller is worn. Or does the exhaust mostly blow air not water?
What do the experts say? Thanks and good boating.
