I got my '63 75 HP Evinrude running tonight in a big tub of water. It ran well for about 15 minutes total, but it couldn't idle. It would want to sputter and die out when I slowly decreased the throttle toward idle.<br /><br />Its also loud as #### and smokes alot! I wanted to test it out on a lake tomorrow to see if the lower unit works. I changed out the impeller and lower unit gear fluid.<br /><br />I guess I need to work on the carb? I haven't worked on one before. Do I just take the carbs off and soak in carb cleaner?<br /><br />Any help is appreciated -<br /><br />Mark
