I bought an old boat with a '63 75hp evinrude, the previous owner said the engine ran 2-3 years ago. I put a battery on it, and it cranks OK. I don't seem to be getting a spark. I pulled one of the sparkplugs and held it to the block, no spark while cranking. I also put a voltmeter on the coil and got no voltage while cranking. What do I check next?<br /><br />Also, a related question. I just bought a '69 85hp Johnson outboard, it supposedly ran last year. I thought about swapping it onto my boat in place of the Evinrude, but I'm not sure if I can. The wiring harnesses look different. The Johnson has a big round wiring connector, the older Evinrude has just a bundle of wires. My evinrude does have electric control for fordward/neutral/reverse, so I think that should be compatible with the Johnson? Would swapping engines just be as simple as getting wiring diagrams and splicing? <br />The Johnson is just laying on my driveway right now, so I can't really check to see if it runs.<br /><br />Any help would be appreciated! thanks!<br /><br />Mark
