63 65hp merc shifter
eschesworld
new to merc outboards and have a 1963 65hp merc i just bought motor and ran it in a tub ran fine but was told to change impeller so i did it was hard put lower unit back on and i had it in reverse i think wont shift out of reverse now
what positsion should shifter be in?lever on motor forward or back? if drive shaft spins clockwise prop counterclockwise when lower unit is in rev?
dakota25
Re: 63 65hp merc shifter
when lower unit is in reverse the prop should only be able to turn in either direction about 1/3 of a turn.
gristock86
hi,
the first thing to remember is NEVER drop the bottom leg in any other gear apart from forward!! so to correct this problem. put the leg back up, shift it into forward then drop the leg again. on the gear selector (just above the gear box towards the rear of the unit) turn it untill the prop is in neutral then bolt the leg back up being careful not to turn the prop in either direction. this should work.
Dont remove the shifter from forward untill the leg is bolted back up it will sync itself if you do this. some motors have 2 nuetrals so if this doesnt work, drop the leg in the same sequence and find the other neutral in the gear box. hope this helps
any other questions or problems please ask.
dan
