joeymagnus1
- Sep 24, 2009
- 7
I just bought a 5 hp SK and I'm having a few problems with it.
1- Does it matter if I use a higher grade fuel? I had some higher grade fuel in my gas can that I had gotten for a scooter.
2- When I first start it, it runs pretty good for a minute , then it starts to stall out. And it kinda revs up and down by itself. Could that be a carb problem?
3- When I run it, I have it sticking in a 5 gallon bucket of water. And after messing with it (trying to keep it running) a few minutes, the water has oil in it. And smoke is coming out of the hole about half way up the shaft. And hot water trickles out of it. But I haven't seen water shoot out of it.
4- The guy I bought it from said it was a 50:1 ratio, but I saw elsewhere in this forum that it's 24:1 ratio for this engine. Which is right? And does it take oil like a car motor does? I don't see any place to check or add oil.
The model # is GG18801A and serial is 36X867736
Thanks
Thanks
