62 johnson sea horse. no spark
Chris435
i have a 62 johnson 75 hp sea horse. i replaced the coil and cleaned and gaped all the points and no spark still. have any ideas. ????
tmcalavy
Re: 62 johnson sea horse. no spark
Check out the thread, "Awakening A Sleeping Outboard." It should get you started in the right direction.
Chris1956
Chris, I will assume you have the magneto distributor ignition. Make sure the wires connecting the two sets of points are not shorting on the dissy rotor or pulley. Make sure the second set of points is set on the timing mark on the pulley base, just behind the flywheel. It is 90 degrees past the first timing mark. Make sure the coil wire is not shorting to the dissy body, where it bolts on. There should be a fiber insulation washer and bead to keep the bolt from shorting out. When you spin the dissy pully the plugs should arc with a snap. if not, replace the condenser. The ground side of the coil is well grounded to the dissy body?
