1stgenbird
- Aug 5, 2009
- 397
I just bought a 62 Fastwin last week for $50. S/N 15036M-06063. Not bad shape overall but I know it has some issues with water in the lower unit. It had been sitting in this guy's shed for 10+ years as it belonged to his father-in-law.
When I initially looked at it and took out the lower drain plug, some clear water came out. By the time I got it home and removed the plug again, a light brown oil water mix came pouring out.
First thing I saw was that neither drain/fill screw had any gaskets so that is probably why water got in there in the first place. On closer inspection, I noticed a slight bulge and crack in the aluminum just below the cav plate. I scratched my head a bit but then I figured out it was likely freeze damage from the water in the lower unit.
I haven't pulled the lower unit off yet, but I have a feeling that the gears are ok. The way the clear water first came out, I think the grease protected the gears, but we'll see.
Looks as if I will need a partial lower unit replacement so I have been checking out eBay. Does anyone know what years and HPs are interchangeable with direct bolt on?
