Howdy all, nice place!<br /><br />Have a 1962 Evinrude Lark IV Selectric Shift, Model# 35933.<br /><br />Last season the motor stopped shifting. When I put it in gear the motor would bog down or stall. Although I found out I was using the wrong oil, it did work up till then.<br /><br />So I took the lower unit off and tore it down. All looked good, so I cleaned it up and put it all back together, using the correct oil this time.<br /><br />After bolting up the lower unit I tested the coils for opperation, heard them clicking and confirmed it with a test light, motor not running.<br /><br />So, hooked up the water muff and fired the motor, runs great by the way! Tried shifting and the prop didn't turn, ?! <br /><br />Not sure how to tell if the shaft went into the spline or not but didn't have any resistance when bolting up the lower unit.<br /><br />What could be wrong?
