62 18hp rude
JKTrevecca
My starter rope is showing signs of wear. Can anyone lead me to step by step instructions on how to replace this so I don't get stranded w/ no way to start my motor?
Thanks in advance!
Jason - Nashville, TN
restornator
Re: 62 18hp rude
take the recoil starter off. pull all of the rope out, secure the spring so it doesn't coil back up. Cut the rope at the anchor ( or knot) if you plan to replace it. Pull rope out. Remove anchor from rope handle and take rope out. Cut a piece of starter rope of the same length plus 4 inches to tie the knot for your anchor. Feed rope through starter apparatus, through the port on the starter wheel. Anchor it in place. Re-attach the rope handle anchor and assemble it back as you took it apart.
