60HP Yamaha 2 stroke
pearldoggy
my outboard runs fine initially then starts to lose RPM after a few minutes acts like a cylinder breaks down
robert graham
Pull each spark plug to try to get a reading on possible problems. Is your fuel tank venting properly?
Sea Rider
Welcome to IBoats,
Troubleshoot each ignition coil with a spark tester. If fine try a new set of NGK spark plugs. If the issue continues could be any electrical component intermittently failing, heats up and misses, those cases are the hardest to diagnose properly.
Happy Boating
