Hello
I have a '87 60hp merc that has ran fine the first 4 trips this year. It started easy yesterday and ran fine up river to where I fish. When done fishing after 4 hours, it starts fine. When I gave it throttle, it hesitated a bit then got up on plane and seemed fine for maybe a minute. Then it started to surge. It still kept speed and never came off plane. I was going 26-27mph. Rpm's where about 5000. I think my speed should have been closer to 29-30mph where the rpms and throttle were at. I put a little pressure on the primer bulb and when I did that it made it worse. Like it's getting to much fuel.
Get back close to ramp, I shut throttle down, ran rough. When I gave it throttle it hesitated way to long then finally shot up, but surging the whole time.
The only thing I did do different is use a different 2 cycle brand for the first time. I used quicksilver, I normally use pennzoil. The oil injection was disconnected by previous owner, so I mix. I only topped off the 6gal. tank with 2 gallons of gas and correct amount of oil.
Sorry if I rambled. Is there any easy thing I can look for before taking it to the shop.
Thanks.
Thanks.
