60hp rude vro/tach
electric000
Hi, new at this, hope I'm in the right place. Did this before but said I wasn't logged in so I'll try again. Had detailed info before but will make this short. 1992 60hp low oil beeps at idle but not at higher rpm's,also the tach is erratic at higher rpm's.Book and tec said regulator, didn't help, could tach and vro be bad? has very low hours and set up for years, other wise in mint condition. any help would be very much appreciated.
npd4432
Re: 60hp rude vro/tach
Sounds like an electrical problem, check the wires for being frayed or grounded out or possibly corroded.
possibly a rectifier.
tashasdaddy
which alarm are you getting ? has it just started this, how cold was it there?
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
electric000
Sorry, meant no oil warning does it only at idle.tach erratic usually about 3500rpm's pegs around 6200rpm's.prop is 131/4x17 on 17ft aluminum.no corrosion, wiring excellent. thanks for your time and expertise
kb3gup
My 92 Johnson 60hp does the same thing. All wiring was good but the regulator was bad. I'm NOT AN EXPERT AT ALL but my motor would run just fine even with the bad regulator. I just replaced it and I'm hoping come summer it will be better.
tashasdaddy
when was the last time the oil tank, filter and hoses were cleaned?
