60hp Power Trim
argoten2
Have had the trim motor rebuilt, replaced one of the two rams, replaced the two large hoses, and re-installed the trim unit and bled the system. It will power "down" from the switch, but won't power "up"! Both solenoids work by hot-wiring them at the pump...
I replaced the fused line with a spade-type in-line and it connects to the "+" terminal. A wire I have loose is the small dark-brown w/white stripe. Does anyone have a wiring diagram, pix, or suggestions?
Thanks...!:confused:
achris
More fish than mountain goat
Re: 60hp Power Trim
Hello and welcome to iBoats....
Due to the large number of different trim systems used over the years, we really need an engine serial number to identify which type of trim system you have. Then we can give you some advice about your problem....
Chris........
