Dave Desilets
- Aug 4, 2008
- 16
2006 Mercury 60HP ELPH EFI Tilt and trim not working. Trying to use cowl switch and got no response except for clicking relay's for both up and down. Battery voltage 12.5V
I tried replacing the cowl switch, no change. Tried replacing both relay's, no change.
Troubleshooting:
Checked fuses: OK None blown and looked clean, checked with meter.
Checked connections at main power and cleaned terminals.
Pulled relay's and checked for voltage from trim switch: Result - OK 12.5V for both up and down.
I pulled one relay at a time jumped red to green, then red to blue: Results: Trim motor ran just fine in both directions, no hesitation, ran perfectly.
Put everything back together with new switch and relays: Results: Same, no op in either direction.
Pulled new parts out and put old parts back in: Results: Same, no op in either direction.
The manual doesn't cover this issue, and after checking the wiring diagram in the manual
I've gone over the whole circuit and looked at everything and cannot find anything that looked broken or suspicious. I've had problems with the helm switch not working with broken wires but the cowl switch has always worked. So everything checked out as far as I can tell, but obviously, there must be a problem somewhere that I'm missing. I'm at a loss, so any help would be greatly appreciated. Thanks! Dave
Troubleshooting:
