HI
I have a 1887 60 hp VRO and it will not idle or switch gears without stalling when placed in the water. When I run it in my driveway with muffs it works fine. I can shift gears forward and reverse numerous times and throttle up and back to idle and no stalling. But when I place it in a water at my local fishing lake it stalls when coming off high idle every time, if I try to slap in gear and high throttle it sometimes works but mostly stalls as well. It is so annoying.
I have had it to my mechanic several times, carbs have been removed cleaned and linkage checked.
Any ideas as to why this happens?
thanks
Don
thanks
Don
