60HP Evinrude water tube replacement
kiwifish
Recently removed LU to remedy lack of water flow to tell tale (thought it was water pump) to find that water tube has cracked & had been filling up lower unit....can you tell me whether the water tube can/should be removed without removing powerhead?
OBJ
Re: 60HP Evinrude water tube replacement
How bout' giving us a year or model number Kiwi. You will probably have to pull the power head to replace the water tube. The end of the tube has a flair on it with a grommet. A service manual will get you through the project.
kiwifish
Thanks OBJ unsure of the year serial number A383402, model number E60TLCNM.<br /><br />Any help would be appreciated
P.V.
Yep, gotta remove the powerhead, gearcase, upper mounts and then the four bolts that remain to remove the adapter housing. Leave the lower mounts in place and the outer exhust will lean back out of the way while still attached to the clamp brackets and the boat! Pull out the adapter housing along with the inner exhust and water tube. Orginally OMC used a rubber grommett that got crimp'd by salt/minerals (just like the 9.9/15 hp motors). Clean out the salt/mineral deposits , the grommett has been replaced by two plastic washers (one on top of the lip of the water tube and one on the tube below the lip) and reinstall everything. Not that hard of a job as long as you don't break off any bolts/screws !!!!!!
OBJ
And to add to P.V.'s good advice, a hoist to pull the power head would be helpful.<br /><br />The year of your engine is 1982.
kiwifish
Cheers guys, will give it a go........Thanks
