Re: 60hp Envirude 1970 Lower Unit Disconnect
HI, Your motor should be an electric shift motor and therfore does not have a shift rod screw. On the port side of the motor, down inside the cowling, near the bottom of the powerhead, next to the exhaust cover, you should see a wire coming up thru plate. Follow the wire and disconnect the two connectors. One should have a green band, the other a blue band. Next, tie a long (4') piece of string (fishing line)to the connectors, tie the other end off on the motor. Spray a lubricant on the cable where it will go thru the hole. Pull the gearcase down. The cable should pull out of the hole. Disconnec thte string and let it sit, while you service the gearcase. WHen you go to put it back together use the string to guide the cable back up into the hole. After the cable is thru the hole, pull the cable itself, to set it in the correct location.
