60 Mercury issues
MAB1
My 2013 60 hp Mercury acts like it’s starving for fuel. It will die and may or may not crank. I can squeeze the primer bulb and it will run , only as long as I keep pumping the bulb. The bulb is good , good fuel. I’ve replaced line . Would the solenoid vale cause this?
Chris1956
Not sure what a solenoid valve is, but your motor has a fuel pump. That could need to be rebuilt. Or you could have an air leak into the fuel line,so the fuel pump sucks air.
