huttbassin
- Feb 18, 2002
- 1
engine would die at idle. checked ball. changed plugs. changed fuel filter. checked fuel pump diaphram. pulled carbs and checked jets and air passages. reassembled. top carb bubbled fuel out of throat area (?). pulled off and tweaked float. ran ok at house , at lake was sluggish out of the hole and at idle after a run would idle then rpms would fluctuate and engine would periodically thump like a cylinder was cutting out. runs fine at cruise and top end. compression 122 top 125 mid 128 lower.fuel prob? vacuum prob? firing prob? auto choke? combination? confussed,need help. p.s. ordered manual.
