Re: 60 johnson compression
Readings are known to vary from 1 manufacturer of testers to another. Difference between cylinders is more important than exact readings.<br />Anything above 100 is usable. All cylinders should be within 10% of each other.<br />Motor off, all plugs out.<br />Crank motor at least 4 turns for each cylinder.<br />If cylinders appear low, sometimes decarb will help.
