buzzman 9403
- Jul 20, 2003
- 51
1989 evinrude get over heat alarm after 5 minutes
replace water pump,replaced vernatherm or Tstat,change prop to get 5000 rpm at WTO,.cleaned carbs,decarboned cleaner,changed plugs,took T- stat out,RUNS COLD,wont idle well,unhooked heat alarm but heads felt hot,pee water was just mild hot,compression is 130 lbs each,(will alarm unhooked still will (slow )switch still kick in when hot)??? any idea what to do next
