2001 Mercury 60HP 3 cylinder outboard has a lean misfire at idle and above. It idles very low and stalls. The misfiring cylinders do come to life if you briefly push in the choke (ignition key) while it is running. Yes, I know it does not have a true choke. I know the following about the engine at this time: Compression 115 psi all 3 cylinders. Fuel filter is new and clean. Spark plugs are new and clean. Float bowls are not plugged with varnish or jelly-like spoiled fuel- I have removed float bowl on dead cylinder to inspect-looked very clean. Fuel is fresh. Fuel is flowing freely to the carburetors.
After tinkering with it in order to learn what I do know to be good it ran normally for a little bit, then went back to the lean misfiring. What do you think I should check next?
