nmhellraiser
- Jun 16, 2007
- 120
I'm helping my grandfather work on his 1984 60hp evinrude. He's having an issue with it getting hot and the overheat alarm sounding. I helped him put a new water pump in it and it's installed right. We changed the thermostat and poppet valve also. It's still getting hot though. We took the lower unit off and pulled out the thermostat and used compressed air to verify that the pickup tube isn't stopped up. Also boiled water and made sure the thermostat was opening. We're getting a good stream of water out of the tale tail. Compression is 150psi on both cylinders. What are we missing?
