6 Lug Rims bolt pattern
agallant80
Are the bolt pattern on 6 lug rums all the same? I am about to order a few spare tires and rims online and want to make sure that I don't order the wrong thing. Venture says that I have the following on my trailer for tires and rims:St 225/75D 15 LRD 6H
The tire and rim I am looking at online is 6 on 5.5 so is 6 on 5.5 onad 6H the same thing?
H20Rat
Re: 6 Lug Rims bolt pattern
No idea what that 6h is for, but as far as I know, 6 x 5.5 is the ONLY current standard for trailer 6 lug wheels. Should be good to go.
agallant80
Yeah that is what I thought. Just wanted to make sure seeing as ordering things online is a bit more difficult to return. Tires and rims ordered.
gm280
You can always measure that 5.5" pattern. In fact on a six lug rim it is very easy to do too. Just take a tape measure (or even a ruler) and measure straight across the center from one lug to the opposite one across the center. That will be the bolt pattern... Center to center will give you that true circular pattern. And a quick way is to measure from the start of one lug hole to the start of the opposite lug hole. That will be equal to center to center as well...
