pontoon chief
- Aug 9, 2004
- 116
I am working on a 6 hp evinrude outboard that will not run without the choke pulled out.I rebuilt the carb and still no difference.Fuel pumps appears to be fine,it pumps when the motor turns over and it seems to have enough pressure.Compression is 80 lbs in both cylinders,and the plugs are good.There is blues sealant smeared all over this motor,so it would appear that someone has has it apart recently.
Any ideas.
Patrick
Any ideas.
Patrick
