6 hp sea king help
greenman51
I have a 6 hp sea king by wards. serial # 66x13161 model #vwb19074a. would like some help finding out the year of this motor and the proper prop pitch and part # for the lower unit bottom seal. any help is appreciated
steelespike
Re: 6 hp sea king help
There is a hole in my info.I believe the 19074 is a 66.Built by Chrysler.
The Chrysler Crew may be able to help. Prop listed is a 7 1/2 X 7 1/2. 2 blade.You may find a seal at an industrial supply where they sell bearings and seals and associated equipment you will need a sample and or the shaft and housing.Also it will need to be rust proof.
