Why do you ask? Engine not performing properly at high speed? There's a high speed jet but it's a precision diameter hole drilled in a brass pellet. Try some Sea Foam per the can's instructions added to your fuel/normal fuel mix if premix. It works real well in cleaning up a dirty engine, both in the fuel and combustion chambers. Available at most all auto parts stores. Give it time to work.
