atticus3600s
- Sep 19, 2004
- 120
1968 6 horse johnson. After running at WOT the engine block is hot enough to burn you in less than 3 seconds. Water is coming out of the pee hole opening in a spray (as I was told it was supposed to)but that water is very hot also-you cant leave your hand trailing in it for very long. Carb. rebuilt last year, compression is 112 and 115 on cylinders 1 and 2 respectively, also I seem to having an intermittent spark problem on one of the cylinders as max RpM's cannot be reached.<br />If anyone has any ideas, they would be greatly appreciated.
